| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50086 09/13/2005 3:43 PM | Joined: May 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: May 2002 Posts: 30 | Hello All, We have a 56 Chevy 3200 longbed 1/2 ton truck, and are installing a 350 and 465 transmission from a 70 Chevy C/20. The 465 has a u-joint yoke attached to the output shaft, but we would like to use a one piece drive shaft which would require a slip yoke into the transmission. My question is (before I go trying to yank things apart), can we just remove the u-joint yoke and find a proper slip yoke to fit or would it require serious modifications to the transmission like changing the output shaft etc? Is there an easy solution or will we be stuck getting a different transmission or fabricating a two piece drive shaft? Thanks, Gene & Jr
horseballz =========== '56 Chevy 3200 '69 Ford F250 '68 Mustang Coupe/5.0 Roller/T5/Factory A/C '03 Miata (Wifes Ride)
#50087 09/13/2005 7:44 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Why not use a driveshaft with the slip part dirrectly after the u joint on the transmission? You know, the yoke about 7" long with internal splines, then the front end of the driveshaft has external splines on the end. | | |
#50088 09/13/2005 9:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A driveshaft shop can make up a driveshaft that will work. Grigg,s setup sounds like the best way. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
