2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#500523 02/01/2009 8:11 PM
I am changing direction in my project because of the economy.I was going to put an IFS in my truck but decided to go with either a dropped front axle or Mono springs and putting in a 261 rather than a 350 .I want to lower the front and rear 3 to 4 inches ,could someone give me there opinion on a Dropped front axle vrs.Mono springs.Thanks for your help.
Don't know what year truck we're talking about here but you won't be able to get a 3 to 4" drop out of mono leafs. You can get an easy 2", maybe a little more with monos. Dropped axles are the way to go if you want to go lower and still have good spring travel. I've got a 3" axle and also removed 3 leafs from the front of my '53 for a 5" drop. You can check prices and get info from Sid at droppedaxles.com.
My truck is a 46 .Sounds like a drop axle is the way I will have to go.Did you have to shorten your stearing arm going 3 inches?Thanks
I just bought a 3" drop axle from Sid @ www.droppedaxles.com.
Hes VERY knowledgeable, and a pleasure to deal with.
I have a 4" axle in my other truck,from a different company and its a little too much, as im running low profile tires.
Contact Sid,He'll walk you thru the process and explain all your different options.
