2 members (Cosmo, Wayne67vert),
43
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 7 Junior Member | | Junior Member Joined: Apr 2002 Posts: 7 | hello all, i came across this old chevy military 1 1/2 or 2 ton 4x4... what kind of transfer case was installed? its hard to tell what year exactly, all that is left are the fenders and frame/running gear... | | |
#5003 05/22/2002 10:41 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Don't know, BUT, if this is WW2 or Korean time truck, bet it had a hydramatic auto trans and tall shift tower into cab and maybe even a multi-speed second trans. Go to the Futureliner site at maybe www.futureliner.com or www.futurliner.com w/out the E in it. It has a military driveline in the old "bus" unit built around late 30's. There are sites on line dealing with just army vehicles, do a search and find/ask those guys!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | My dad and I used to have a '42 Chevy military 1 1/2 ton 4x4, and it had a manual transmission (engine and transmission were out of a '52 GMC 6x6, but the original driveline was included, and it was also manual). Don't remember what kind of transfer case was in there, but it had some enormous knuckles on the front axle. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | T-case is most likely Spicer or rockwell.Keep looking and you will find
#5006 05/23/2002 12:23 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The transfer case in the WW2 and Korean vintage were made by GM (at least the ones that I own) I'd bet that the earlier ones were also by GM.
Jason
| | | | | Joined: Apr 2002 Posts: 7 Junior Member | | Junior Member Joined: Apr 2002 Posts: 7 | ok, dumd question#2
where on thetransfer case do i look for the numbers.. i know where on or about to look on the 203,205, 208,241, all the new stuff..
thanks for all the help so far!! | | |
