| | | Forums66 Topics128,192 Posts1,057,353 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 11 New Guy | | New Guy Joined: Jan 2009 Posts: 11 | clean truck and making it better.where to go for brake help.(parts/service manual)& suspension & wiring ??????? want to make a nice BOLT !!!! what catalogs to order ? | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | I get my big bolts parts from Jim Carters . I'm waiting for my rear wheel brake cylinders to come in than I'll put on the new master cylinder / front and rear wheel cylinders . You'll need a axle nut socket to keep from buggering up the six lug axle nut - replacment costs about $40 each so be careful (1st hand knowlege) . Look in the tech tips for help on some of the brake/axle questions . Axle nut/socket info is in a post in this or the general truck questions forum. Hope this helps and have fun . ED H | | | | | Joined: Jan 2009 Posts: 11 New Guy | | New Guy Joined: Jan 2009 Posts: 11 | | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Contact Geoff at, Alretta Truck Parts, for all brake related parts. ph.(508)788-9409. | | | | | Joined: Jul 2008 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 39 | Although I do not have a truck yet, I would reccommend Jim Carter hands down. He has helped us out, as we have been looking at trucks and have run into many of the same problems: Brakes. My dad met him at the Hershey, PA swap meet (we're less then 50 miles from hershey) and talked to him quite a bit on tips and tricks. His catalog has everything you can imagine and then some. Go with Jim Carters, you wont be dissapointed.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Alretta has more large truck related brake parts. Jim Carter would definitely be my choice for trucks 1 ton, & smaller. | | |
