4 members (Bill Hanlon, Shade Baby, Deegs53, Gray_Ghost), 159 guests, and 1 robot.
Topics128,192
Posts1,057,350
Members48,469
noz
Offline
clean truck and making it better.where to go for brake help.(parts/service manual)& suspension & wiring ???????
want to make a nice BOLT !!!! what catalogs to order ?
I get my big bolts parts from Jim Carters . I'm waiting for my rear wheel brake cylinders to come in than I'll put on the new master cylinder / front and rear wheel cylinders . You'll need a axle nut socket to keep from buggering up the six lug axle nut - replacment costs about $40 each so be careful (1st hand knowlege) . Look in the tech tips for help on some of the brake/axle questions . Axle nut/socket info is in a post in this or the general truck questions forum. Hope this helps and have fun . ED H
noz
Offline
thanks ed
Contact Geoff at, Alretta Truck Parts, for all brake related parts. ph.(508)788-9409.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Although I do not have a truck yet, I would reccommend Jim Carter hands down. He has helped us out, as we have been looking at trucks and have run into many of the same problems: Brakes. My dad met him at the Hershey, PA swap meet (we're less then 50 miles from hershey) and talked to him quite a bit on tips and tricks. His catalog has everything you can imagine and then some. Go with Jim Carters, you wont be dissapointed.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
Alretta has more large truck related brake parts. Jim Carter would definitely be my choice for trucks 1 ton, & smaller.
Spanky Hardy
1950 GMC 250 1-Ton
