8 members (Robert Crandall, Wayne67vert, Uncles51, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps),
79
Mod | | | Forums66 Topics128,041 Posts1,055,480 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50010 09/11/2005 2:41 PM | Joined: Dec 2004 Posts: 21 Junior Member | | Junior Member Joined: Dec 2004 Posts: 21 | Hi All. Old truck has been running fine until recently. Died while driving. Cleaned the fuel pump bowl out and truck would fire and idle but would not let me drive at any speed without dying. Pulled the carb, cleaned and put a rebuild kit from LMC in. I must of did something wrong cause now it will only fire with a squirt of starter fluid and than die. Yes, the fuel pump seems to be pumping. Before I pull the carb and start to backtrack, got any sugestions? Truck is an unrestored '47 with original 216, saved from a South Dakota farm last summer. Thank for the help. Bob | | |
#50011 09/11/2005 10:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Disconnect the fuel line from the carb & crank it. You should get astrong shot of fuel & several cranks should put several ounces in a bottle or can. Make shure it is gas. Sometimes you can pump pure water. If you have a roch. model B carb they are very simple. You can take the top off & make shure you did it right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50012 09/13/2005 5:40 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | |
