11 members (dt235sd, BC59, cmayna, 66flea, Bill Hanlon, Otto Skorzeny, greenie-reddy, TexasFarmTruck, DennisM, Thom75, 1 invisible),
187
Mod | | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49997 09/11/2005 3:38 AM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | Me again. Got the new gas tank in '51 Chevy completely assembled and in the truck with lines run. Put gas in it tonight and it is leaking around the brass nipple that screws into bottom of tank and goes through cab floor. I put the thread sealer on the nipple. I've seen some other threads that complained about the new gas tanks. Anyone have any thoughts/solutions? I was ready to crank up for the first time today, but don't think I want to try with leaking tank!
1951 Chevy 3100 w/235
#49998 09/11/2005 11:04 PM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Hi magnmike, I am one of those who responded to your last question about the new tanks. I told you that I too had the same problem. The new tanks have a design flaw. I never could get mine to seal up either, and I feel that as long as the repro. mfg. continue to make them with the current design at the bottom, there are always going to be problems. On the original Chevy tank, there is a round, flat plate on the outside of the tank, that the brass nipple screws into. This is what the nipple tightens up against, and makes a tight seal. On the new tanks, there is no plate on the bottom. Just a threaded hole. Like I said, I never could get mine to seal either. I ended up taking my new tank back to Chevy Duty, and got some muratic acid, and a clean amd seal kit from Eastwood, and reconditioned my old tank. That was last summer, and so far, no problems. KT ------------------- 1949 3/4 ton Chevy
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#49999 09/12/2005 3:47 AM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | I may have to try that. I had originally taken my old tank to a radiator shop, but they said it was so bad that they didn't think it was worth boiling out.
I did speak with one individual who indicated that I may can try welding the pipe nipple to the bottom of the tank. By placing the weld on the outside, it may keep the tank from leaking.
Anyone tried this approach?
#50000 09/12/2005 2:31 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I know we've been through this before, but I'm a big fan of JB Weld, and have used it to fix a lot of things...Had some stripped out screw holes for my inside visors, filled with JB, drilled with small hole,retapped with original screws...problem solved..Anyway, If there is a way to seal the area that is causing a problem, let it sit for awhile, putting some sealer on that pipe nipple, and giving it another try, that's what I would do..Just my 1 1/2 cents..Steve | | |
#50001 09/12/2005 3:04 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you can't or don't return it you 'may' be able to drill out the hole and tap it to the next larger size &/or bush it to fit the correct pipe. just a thought...
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
