| | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | the truck has a serial # 5VJA and the engine is KCA34792 the engine has a slight rod knock on #5 cyl. when I pulled the rod cap the babbit on the rod was gone when did the engines go to removable bearings and not babbeted rods and what size cid blocks will work with this eng. the thing looks and runs like a top WHAT WOULD YOU DO ? | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | I also have 2 52 burbs that may have doner parts (rods&crank) is it worth looking into swapping parts | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | KCA is the 216 engine serial number prefix in 1952.
Insert/removable rod-bearings were first used in trucks in the 1954 235/261 engines. Insert rod bearings were never used in original 216 engines.
"and what size cid blocks will work with this eng." Are you asking about a replacement block or a replacement engine?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The babbitt on those rods was somewhere between .004 and .007" thick. If you think that the crankshaft can be used as is, the rod can be machined to accept inserts. The inserts are made just for those rods when they are converted. That is what I did with mine and they have worked well for me. | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | "and what size cid blocks will work with this eng." Are you asking about a replacement block or a replacement engine? _________________________ block I have found a casting #3837004 55-57 235 short block with a freshly turned crank and new pistons it has the harmonic balencer and the stock flywheel for a three speed manuel trans for $100.00 at a local machine shop the customer went to a small blk. will my head/manifolds & work on that 235
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Master Parts Book lists a different part number. for 1952 216 and 235 heads. The side cover on the 216 is different from the side cover on a 1950-1953 235. The 216s' (and pre-1950 235s') had a side cover that came up, over the side of the head; the 1950-1953 235's side cover did not extend above the block. | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | thanks I bought the engine anybody have a idea for cam something mild for towing for a 55-57 235 | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Check the Links -- guys like Tom Langdon at Stovebolt Engine Company have some pretty interesting performance parts for that engine.
You might also ask in the HiPo forum.
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
