3 members (DoubleB, Chip O, JW51), 173 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#498874 01/29/2009 2:01 AM
I'm trying to take out the tranny on my 235. I already took the 4 bolts from the tranny but inside the bellhouseing there is a fork like rod that sticks out.Do I need to take that off?so far I'm stuck.
No, the fork can stay in position.
Is the throw-out bearing stuck to the shaft? It should slide straight out (heavy) if it has been sitting along time the splines on the clutch disc and the pilot bearing are the only other things that would be holding it.
Its been sitting for a year or so.Do I need to take off the throwout bearing?
There should be nothing else holding it. Try grabbing the very rear of the trans and shaking it. Its heavy, be ready to catch it. I cut the heads off of a couple of long 1/2" bolts and threaded them into the two top holes to use as guides. This helps the trans come straight back a couple of inches so you can get it loose without it falling on the floor.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
YES... I got it out.Once I took the fork shape thing that was sticking out the left side of the bell it came right out.(I dont know what its called). thanks for the help Stovebolters.airchevy
It's actually called the "clutch fork". Do you have a shop manual? They are really handy, show up on eBay from time to time and reprints are available from most classic parts vendors. Good luck!
Professional Novice
ClutchFork.got it.I dont have a manual anymore my dog ate it.I'll get a new one soon.
