6 members (greenie-reddy, FAST55, MRMEROTH11, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln), 107 guests, and 1 robot.
Topics128,051
Posts1,055,768
#497822 01/26/2009 5:38 PM
Apprentice
Apprentice
When there has been an updated suspension put on a truck or car how does the alignment get checked? I know most vehicles have spec numbers for alignment, but how do they do it on stuff that has been put on an older car or truck?
Just trying to get a little educated here, thanks.
H Online: Content
Start with the alignment specs for the donor vehicle, and hope the person or shop that did the swap knew what they were doing. There are so many variables like ride height, spring rates, wheelbase, scrub radius, Ackerman angles, etc. that any alignment attempt is only going to be a WAG. Tinker with it a lot, and see what works for the best handling and tire wear results. Some of the aftermarket kit suspensions get things so out of whack trying to get the slammed look that there's no practical way to make the alignment work.
Apprentice
Apprentice
It's all the geometry that messes me up I think.
Stevea #497981 01/27/2009 12:45 AM
Riding in the Passing Lane
You should start with basic settings & see how it drives & watch tire wear like Jerry says. I would set it at 1-2 degree pos. caster. -1/8 to +1/8 camber & 1/8" toe in.
1972 Chevy c10 Cheyenne Super
