7 members (mick53, Bill Hanlon, klhansen, mason86, Otto Skorzeny, Hawkman, festerhairball), 76 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#497750 01/26/2009 11:23 AM
on my 1952 3600 has safety rim are they easy to mount new tires i want to get coker white wall but the local shop wont mount them unless there there tires which they dont carey
32fire2 #497779 01/26/2009 3:17 PM
32, this topic has been discussed before, try to doing a search for quicker results. I tried to get the safety ring off the wheel before (with NO air in tire), but I couldn't figure it out. So, there is a trick to it, and I'm sure someone can give you better tips than I.
The Coker people should be able to set you up with someone in your area that will do them for you.
1951 1 Ton Completed
