| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49767 08/31/2005 4:02 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | my exhaust manifold gasket (53 gmc/228/6cyl) is burned out on one cylinder and even though it sounds pretty cool (almost like it has headers), i'm wondering how bad is this? 1. how urgent is it that i replace the gasket? 2. do i have to pull the intake and exhuast manifolds off as a unit? 3. can i replace the manifold gaskets without breaking loose the exhaust manifold-to-exhaust pipe intersection with the donut gasket inside? it is 'welded' shut with heat and rust and the 3 bolts/nuts look like they've sat in acid for a few weeks; totally deformed! If I can prop up the manifolds from underneath and replace the intake and exhaust gaskets, i think i'd rather do that, but i'm not sure as i've read on here that i'm supposed to have them planed down even before i put them back on. HELP!
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#49768 08/31/2005 4:21 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Well, one thing for sure, the exhaust manifold studs are always a problem from the heat cycles and rust. Better start putting the liquid wrench on them way before you need to un do them.
The immediate danger would be if you smelled exhaust and were breathing fumes. Eventually it will burn up the manifold though and then it might take two gaskets to fit tight (I had that problem with a 230 ci 6 in a camaro). | | |
#49769 08/31/2005 2:47 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | old_blue-
You can change the gaskets without removing the manifold from the pipe. Just unbolt it from the head and let it hang on the exhaust pipe.
The next question, though is whether the gasket was old and just happened to blow or is the manifold surface warped. I would replace the gasket and keep an eye on it. If it starts leaking again pretty quick, that would indicate a warped manifold surface. Then you get to have the fun of removing it. Like arnswine said, start soaking them with PB Blaster or something now. And don't freak out if a stud breaks off. They aren't hard to drill out and re-tap when the manifold is off.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
