0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#497652 01/26/2009 4:02 AM
I am changing out my 235 with a different one. the one I am getting has the bellhousing on it. any sage advise I might need before I do this?
56 stepside 3/4 ton longbed
56 stepside #497815 01/26/2009 5:02 PM
It would be better to use as many of your original parts as possible since they fit your application. If the bellhousing on the new engine is from a car it will not work in a truck. Also, car engines use different mount locations so you will need to work that out. Otherwise it should be a drop in.
Fred
