1 members (Lightholder's Dad), 66 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#497260 01/25/2009 2:11 AM
Apprentice
Apprentice
Another question about the driveline. On this '35 1-1/2 Ton. Can you still buy a replacement Clutch, Pressure Plate, Trow-out Bearing. The clutch has seen its day. The Pressure Plate looks like something you would see in a museum. Seriously it does look like it could be taken apart, and at least cleaned. Maybe have the disc side turned. Have the Flywheel turned and a little dressing up of a few of those teeth. Does this at all sound like the right approach? Any thoughts please. Thanks, Tom
I sent you a Private message, check it out.
