| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 36 Apprentice | | Apprentice Joined: Jan 2007 Posts: 36 | Another question about the driveline. On this '35 1-1/2 Ton. Can you still buy a replacement Clutch, Pressure Plate, Trow-out Bearing. The clutch has seen its day. The Pressure Plate looks like something you would see in a museum. Seriously it does look like it could be taken apart, and at least cleaned. Maybe have the disc side turned. Have the Flywheel turned and a little dressing up of a few of those teeth. Does this at all sound like the right approach? Any thoughts please. Thanks, Tom | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I sent you a Private message, check it out. | | |
