8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 11 New Guy | | New Guy Joined: Jan 2009 Posts: 11 | Hi, I'm rebuilding a Roch. B carb and the exploded view on the instructions show the fuel filter separating from the fitting and gaskets. The view provided is of a "BC" model. My filter won't separate, at least not easily and if I force it I'm afraid it might break. And I can't find one anywhere on the internet, not one in the rebuild kit either so I definitely don't want to break it. Also does anyone know where I could get an air filter stud, and period air filter for it? Thanks, Brett
'50 Chevy 3100 http://www.flickr.com/photos/34731099@N06/?saved=1 '63 GMC, gone but not forgotten!
| | | | | Joined: Jan 2009 Posts: 11 New Guy | | New Guy Joined: Jan 2009 Posts: 11 | BTW the carb is off of a 63'-65' 230 motor, not the one off the original 216, which I don't think has an air cleaner stud. Brett
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brett, This page might help you confirm the identity of your carb. Late 235/261 engines (pre-'63) had air cleaner studs. For a stud, buy a piece of threaded rod from any hardware store. Maybe someone else will know what year Rochester one-barrels (on trucks) had the center studded air-cleaners. I would guess 1958-63. Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is the brass filter stuck to the filter inlet nut? If that is the case a little carb cleaner should get it off. They are available at any parts store. Just tell them you want the GM brass fuel filter. They used the same one for many years. I have the air cleaner stud but like Der Man says you can make one out of threaded rod available at any hardware store. If you cant find the filter let me know. I can send one or get the part number. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 11 New Guy | | New Guy Joined: Jan 2009 Posts: 11 | Thanks for the advice. The filter was soaked again overnite and still wouldn't budge, so after a few hefty whacks it finally came loose. The gasket was completely gone and filter seized to the fitting. But after cleaning I think it is still usable. As for the air filter stud, threaded rod is a good idea as soon as I get an air cleaner cleaner to size it up. Was the original for the 230 an oil bath type? Thanks again, Brett
