| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49702 08/29/2005 7:31 AM | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | how do you till what you have solids or hyds? | | |
#49703 08/29/2005 7:48 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | First, what engine do you have and what year is it?
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#49704 08/29/2005 10:16 AM | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | | | |
#49705 08/29/2005 12:29 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Most likely solid lifters in that engine.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#49706 08/29/2005 12:56 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kemps,
A passenger car 235 from around 1960 would most likely have hydraulic lifters, while a truck engine would most likely have mechanical lifters.
The best way to determine haydraulic/mechanical is to look at the lifters. The next best way is to find and post here the block casting number (on the block at the upper right of the starter motor - sometimes hard to see) and/or the engine "serial number/ID", which is pressed into the block on a ledge to the rear of the distributor.
If my locations for codes are wrong, or if there is a better way to answer your question, someone will most likely let us know,
Tim | | |
#49707 08/29/2005 2:35 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I agree with Tim, but about the cars having hydraulics and trucks having solids originally, but I wouldn't trust the casting numbers to tell me what it should have. All 235 blocks from '56 up were drilled for hydraulic lifters. So, over the years, the original ones could have been replaced. It may take a little work, but I would pull one to remove all doubt, because hydraulics won't work with a solid cam, and solids won't work with a hydraulic cam.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#49708 08/29/2005 4:24 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Here's a quick way to check for hydraulics. Remove the valve cover, and get a valve close to fully closed. Clamp a pair of vise grips on the rocker arm, and exert a firm, steady pressure toward the pushrod for a couple of minutes. If the lifter is hydraulic, the clearance between the rocker arm and the valve stem will slowly increase until there's about a 1/8" gap above the valve stem. As soon as the engine is re-started, the lifter will pump up to zero clearance again. Jerry
#49709 08/29/2005 6:35 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jerry,
Thanks for the technique - I thought that there had to be a good way to test it easily.
Tim | | |
