0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 77 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 77 | I have looked at others but have never seen any others with that long of a shaft. Thanks for the reply!
John Kinser
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kinser1970,
I'll go out on a limb here and say that is not a fuel pump for the application listed...it is for some other engine, not a Chevrolet.
Stuart | | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | Kinser1970,
Stuart I am with atomarc | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The housing stamped #4149 is for '55-57 ALL 6cyl.(2nd ser)original pn 5593247. But that long arm still doesn't look right. As far as I know they didn't move the cam to the other side of the block on the six cylinder engines in '55. Rebuilt Delco starters and generators often have the wrong tags on their housings leading you to believe you have the wrong part. The housings are the same for many applications, just the end frames being different. My guess would be that, the same AC fuel pump housings would fit many different makes and models and the only thing different is the arm. The rebuilder probably swapped arms and boxed it up for '37 Bastich or something that they needed at the time and didn't bother with the stamped number. The auto parts just assumed by the number that it was for the tri-five Chevy 6’s. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | I'm doubting it, I think you should play it safe and try to swap that pump for a GM pump. I got a brand new 54 Chevy fuel pump at Napa no prob. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Check out Ebay item number 390024015817 It is a Ford fuel pump.
Marv.
