Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (78buckshot, Hotrod Lincoln, klhansen, DoubleB, 55shaker), 113 guests, and 4 robots.
Topics128,288
Posts1,058,577
Members48,492
#496200 01/22/2009 4:39 AM
I bought this fuel pump off of Ebay. When comparing it to mine, the shaft that works off of the crank is very much longer than the one off of my truck. Will this still work?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270324405103&viewitem=
John Kinser
#496207 01/22/2009 4:48 AM
I have looked at others but have never seen any others with that long of a shaft. Thanks for the reply!
John Kinser
Kinser1970 #496231 01/22/2009 5:24 AM
Kinser1970,
I'll go out on a limb here and say that is not a fuel pump for the application listed...it is for some other engine, not a Chevrolet.
Stuart
atomarc #496291 01/22/2009 7:47 AM
Originally Posted by atomarc
Kinser1970,
Stuart
I am with atomarc
Slickt #496340 01/22/2009 1:28 PM
The housing stamped #4149 is for '55-57 ALL 6cyl.(2nd ser)original pn 5593247.
But that long arm still doesn't look right. As far as I know they didn't move the cam to the other side of the block on the six cylinder engines in '55.
Rebuilt Delco starters and generators often have the wrong tags on their housings leading you to believe you have the wrong part. The housings are the same for many applications, just the end frames being different. My guess would be that, the same AC fuel pump housings would fit many different makes and models and the only thing different is the arm. The rebuilder probably swapped arms and boxed it up for '37 Bastich or something that they needed at the time and didn't bother with the stamped number. The auto parts just assumed by the number that it was for the tri-five Chevy 6’s.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I'm doubting it, I think you should play it safe and try to swap that pump for a GM pump. I got a brand new 54 Chevy fuel pump at Napa no prob.
Check out Ebay item number 390024015817 It is a Ford fuel pump.
Marv.
