11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible), 109 guests, and 4 robots.
Topics128,056
Posts1,055,789
#49586 08/27/2005 6:33 PM
Junior Member
Junior Member
My dad and I worked on my 54's 235 last summer. We couldn't finish during his visit, and I never got back to it until now. I had set the valve lifters only part way back into their guides, just to keep track of their original position. Of course, I was going to get right back to the project, but... Now they're stuck and I was wondering what the best method of unsticking them would be. I was able to remove two of them. They have some surface rust, which when removed with 0000 steel wool, just leaves some gray spots and no roughness. I've soaked them with WD-40, and grabbed them with a ragged-wrapped set of channel locks, but they don't budge. Is there some super penetrant out there that would help? Any ideas?
#49587 08/27/2005 7:59 PM
Some people swear by "P B Blaster" for penetrating oil.
#49588 08/27/2005 8:29 PM
www.kanolabs.com
Kano Kroil is the best penetrant there is, bar none! The U.S Air Force must agree, because it's on Bench Stock at every USAF maintenance facility I've ever worked. Soak the stuck items overnight, then use a plastic-tipped mallet or a brass drift and a ball peen to move them a little. A day or two of soaking and tapping should free everything up nicely.
#49589 08/28/2005 3:41 AM
Junior Member
Junior Member
Thanks for the advice. I bought PB Blaster, since Kroil is only available via mail/web order. 5/12 unstuck immediatlely. The remainder are soaking. Since I don't have a brass drift, I may use a wooden dowel and see if that works. I'll keep soaking and tapping. Thanks for the advice.
#49590 08/28/2005 12:49 PM
I
I Offline
I agree with Hotrod... Kroil is King.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#49591 08/29/2005 7:42 AM
Junior Member
Junior Member
With the pan off, I just tapped them up and out with a foot-long wooden dowel. Piece of cake!
