1 members (Jon G),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Hi, I just pressed the support bearing off my front driveshaft and I have a problem. Once the bearing retainer was pressed off the shaft, the bearing fell off the shaft. The area of the shaft where the bearing seats is pretty chewed up and about .050 undersized now. So I need a front driveshaft for a 59 3600. Does anyone know what years will interchange? The shaft diameter at the splines and the bearing mount area is 1 3/8", and the shaft length is 36". The u-joint is 3 5/8" x 3 5/8" with 1 3/16" caps.
Thanks, John | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Could be simpler to take it to a driveshaft shop and have them replace the splined end, or build a new shaft, could even use a new style carrier bearing if you wanted to. Otherwise you're searching in junk yards.
Grigg | | |
