Lost my "as was" picture of the axel/bearing seals on the rear.
At 22 bucks each, and the shape of the old ones after my removal, I want to make sure I press them in correctly.
Not sure how to identify the two metal sides so... I am seeing one side wider than the other, the narrower(a) allows you to see the most of the rubber seal that is "bonded" to the wider of the metal sides (b).
Which face, a or b faces outward?
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
