3 members (KEVINSKI, 68ironhead, 1 invisible),
103
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | I like to remove some leaves to get a softer ride since I'm not loading my truck anymore (55 1st serie chevy 1/2ton)
I have 8 leaves in the back, how many should I take out to get a better ride and where?
How many can be taken out in the front by a 350/350 combo?
Thanks | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hello. i have a 57 1/2 ton, and i removed 4 of the original 7 in the rear, leaving me with 3. in the front i have a 350/350 also, but went with a 3 inch dropped front axle, but also removed 1 leaf, the shortest, and that got me another 5/8" drop. so maybe you could take 2 leafs out of the front and see how it does. not sure if i would remove more than that.
it softened the ride up considerably. hope this helps. leonard | | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I have the same setup in my 51 and I thought about removing some leafs also, but I had too much trouble getting the steering linkages set up correctly on the power steering to go through that all over. But removing a few leafs would help, the 350 weighs a little less than the old 216, and sits back farther so the front is pretty rough riding. | | |
