5 members (Nuts&Bolts, Joe H, baldeagle, Shade Baby, dt235sd), 66 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#493990 01/16/2009 3:43 PM
Looking for some input on conversion. Not sure if i want to go the 6 lug route or 5 lug. If i go the 6 lug i will not have to replace my chrome reverse wheels. I am using a 15" 6 lug wheel now. Will the wheel work or do they need to be 16" with this kit.That is my main concern. I have read the various posts and just want some feedback.
Mike
46 1/2 ton
I want to say you can use your 15" wheels, but I will say you should be able to use them if they are later model wheels that are made for disk brakes. The 15" and 16" stock wheels will not work with the disk conversions without using a spacer.
Go to parts for sale. I have a 6-lug disc brake set up for sale.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
2 Offline
Mike, I went with the 5 bolt lugs on my '51 because I'm using a posi rear end out of a '77 Trans Am. The stock wheels off the Trans Am fit on my front conversion Disk Brake Kit I bought from Jim Carters. I did not need the spacer in my applacation. Worked out well for me. Good luck!
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one.
-Ralph Waldo Emerson-
