| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | Looking for some input on conversion. Not sure if i want to go the 6 lug route or 5 lug. If i go the 6 lug i will not have to replace my chrome reverse wheels. I am using a 15" 6 lug wheel now. Will the wheel work or do they need to be 16" with this kit.That is my main concern. I have read the various posts and just want some feedback.
Thanks Mike 46 1/2 ton
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I want to say you can use your 15" wheels, but I will say you should be able to use them if they are later model wheels that are made for disk brakes. The 15" and 16" stock wheels will not work with the disk conversions without using a spacer. | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Go to parts for sale. I have a 6-lug disc brake set up for sale.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
| | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Mike, I went with the 5 bolt lugs on my '51 because I'm using a posi rear end out of a '77 Trans Am. The stock wheels off the Trans Am fit on my front conversion Disk Brake Kit I bought from Jim Carters. I did not need the spacer in my applacation. Worked out well for me. Good luck!
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
