2 members (baldeagle, dunfire),
50
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | My '70 C10 has developed a lighting problem. This involves all lights; headlights, tail lights, dash lights, etc. The lights are continually dimming and brightening. The charging gauge is continually changing from about mid point to around 3/4 or less. I have checked all grounds by disconnecting, cleaning and connecting again. The alt belt is tensioned ok.
What is causing this? Is the altenator bad?
This is driving me nuts and I know drivers in front of me are wondering what is going on. I feel like I am driving a giant strobe light. | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | This sounds like a main power wire that has a poor connection. If all the lights are powered through the main headlight swith, which I think they are, then I would start there first. Maybe the switch itself is going bad. With the truck off, turn on your lights and watch to see if they dim, try wiggling the shaft of the switch to get them to flicker. Hopefully it is just a loose connection.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Rcimp, I will check out the switch and see what happens. I have been told that the truck should have a ground strap from the engine block to the body. I just went out and looked and I did not find one. The negative battery cable grounds to the engine block but no strap from block to body. Could this be the problem? | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Just went out and turned on the lights, reached under dash and wiggled the wires connected to he switch. The lights did not change so I guess that is ok. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Do your battery posts need to be cleaned?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Battery posts are clean, no problem there. | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | Improper grounding will always be an issue. If you know there is supposed to be a ground strap from cab to engine and there is not one then add one. Maybe there is one and you just can't see it, (maybe under the cab?). The lights are grounded to to the body, but if the body is not grounded to the engine then the only grounding will be between the cab and fram via the mounting bolts, and they are probably corroded. I would go to your local auto parts and buy a ground strap and install it. It certainly won't hurt.
| | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Does it only happen when you are driving? Or does it occur while the truck is parked, engine running with the lights on?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | While it may not be the problem, this is a classic alternator/regulator symptom. If nothing else pans out, you may want to take the alternator (some have built in regulators) to a parts store that checks them. | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | It also happens while parked with the engine running and lights on. I installed another ground from engine block to the body and that did no good. As soon as I get a chance I am going to have the alternator checked out to see if that is the problem. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | In that case, I agree with what Donsz sez.
