3 members (Hambone, 3B, 2-Ton),
145
Mod | | | Forums66 Topics128,084 Posts1,056,087 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 50 | Would the front disk brakes off of a 71 chevy 1/2 ton work on a 70 GMC 3/4 ton? 1949 Chevy 4400 GrainbedIn the Stovebolt GalleryPhotobucket picturesThe taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back! Behind every successful rancher is a wife who works in town.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You would have to sap the entire knuckls plus change the balljoints over to the '71 design to make it work. The prop valve would also have to be used. Are you planning to change the rear to 1/2 ton also?
Bill Burmeister | | |
