0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#49538 08/26/2005 4:28 PM
Hi,
We have the 350 and 4-speed transmission from a 70/C20. What transmission is this likely to be and does it have a synchronised 1st gear? Where do I look for numbers for ID? Last but not least, how well will this fit into our 56/3200 along with the the 350? Being that the 3200 is long bed/wheelbase, does it need a 2 piece driveshaft or what?
Thanks to all,
Gene & Jr
horseballz
'56 Chevy 3200
'69 Ford F250
'68 Mustang Coupe/5.0 Roller/T5/Factory A/C
'03 Miata (Wifes Ride)
#49539 08/26/2005 8:19 PM
Riding in the Passing Lane
I don,t know what the number designation is but practicaly all 68 up used the Muncie trans. It is not sycro. in 1st gear But is a rugged trans. It should fit right in if you use the bell housing with it. If you are switching from a 6 cyl you will need the front mount brackets. Chevy duty has a complete kit. A little expensive but is complete. I have a 55 3200 & it uses a 1 piece driveshaft. You will brobably have to have the driveshaft modified to fit.
1972 Chevy c10 Cheyenne Super
#49540 08/26/2005 10:23 PM
I think they went from an sm420 to an sm465 transmission and i think you can still get parts for the 465.....420 are hard to get parts...and no on the synchro
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#49541 08/27/2005 3:20 AM
Tranny should be sm465, reverse to the right and back. Go to Novak for info. They also have seals and such.
http://www.novak-adapt.com/knowledge/transmission_gateway.htm
If your truck had the 4 speed, it will be no problem putting in the sm465. It's bigger and heavier than the sm420, which should have been what was in your truck. Either tranny will bolt to the bell housing for the sm465. I like the sm420 better, mainly because it will shift faster.
Two piece shafts are recommended for the long bed, but not mandatory.
Fred
52 3600
69 C-10
