3 members (Gib70, baldeagle, 68ironhead), 153 guests, and 2 robots.
Topics128,048
Posts1,055,666
#495263 01/20/2009 12:17 AM
I have a 64 Chevy P/U and just picked up a grill support panel from a 62 or 63.
When I look in the parts catalogs they sell these and list the different years separately. I would have thought they were the same through these years.
Can someone tell me the difference between the years and if what I have will work for my 64.
sorry i'm not up on the correct lingo, if you aretalking about the rad core support that the grille bolts to it will work. i thing the 63 has one less mounting hole for the grille but you can just use the 3 others on each side and it will work fine. if you mean the supports from the fenders running up to the core support i think they will interchage as well. good luck, if i'm wrong you can have your money back!
hoggyrubber, I think you got it. I will take my grill and line it up and see what I have.
Thanks for the post.
i bet it will work, i have swapped several 62 & 63 to 64 to 65. my 63 has a aluminum grille off a 65 right now.
