| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I have a 64 Chevy P/U and just picked up a grill support panel from a 62 or 63. When I look in the parts catalogs they sell these and list the different years separately. I would have thought they were the same through these years. Can someone tell me the difference between the years and if what I have will work for my 64. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | sorry i'm not up on the correct lingo, if you aretalking about the rad core support that the grille bolts to it will work. i thing the 63 has one less mounting hole for the grille but you can just use the 3 others on each side and it will work fine. if you mean the supports from the fenders running up to the core support i think they will interchage as well. good luck, if i'm wrong you can have your money back! | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | hoggyrubber, I think you got it. I will take my grill and line it up and see what I have. Thanks for the post. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bet it will work, i have swapped several 62 & 63 to 64 to 65. my 63 has a aluminum grille off a 65 right now. | | |
