4 members (Otto Skorzeny, Samantha, Jon G, cmayna), 112 guests, and 2 robots.
Topics128,071
Posts1,055,901
Members48,429
#494882 01/18/2009 10:27 PM
I ran across this in the 41-47 shop manual, it may help someone working on there steering box. It also will help if mixing parts around to make one good one like I did. Joe
" NOTE—Due to a design change after the beginning of 1942 production, the early 1942 trucks, conventional and Cab-Over-Engine, contained the same design steering gear as used throughout the 1941 production year on all trucks. The 1941. 66 (1/4") ball type, steering gear in a 1942 truck may be identi­fied as follows:
ON CONVENTIONAL MODEL TRUCKS-by the size of the bolts used to attach the side cover to the housing —5/16" diameter. The 1942, 60 (9/32") ball type, truck steering gear has 3/8" bolts at this point. ON CAB-OVER-ENGINE MODEL TRUCKS-by the casting number cast in the housing on the pitman arm side—No. 266856. The number cast in the housing at this same place on 1942, 106 (9/32") ball type, truck steering gears is No. 267135.
Complete steering gear assemblies are inter­changeable between respective model 1941 and 1942 trucks. All overhaul and adjustment instruc­tions in the 1941 Shop Manual covering the 1941 66 (1/4") ball type truck steering gear apply to this first or early design 1942 truck "
So, does this mean that 1941 was the first year for the recirculating ball steering, but the balls were bigger starting in 1942? I wonder if bigger balls gives lighter steering (insert joke here)? I'm still looking for a true recirculating ball steering box and column for mine and I'm not sure what year to look for.
1938 HC half-ton - Buford
1954 Chevy 3600
2024 Chevy Colorado
I believe '40 was the first year, and sometime in '42 they switched to the 9/32" ball over the 1/4". The ratio is the same for each box, about 20 to 1. The 3/4 and 1 ton use the same box only the shaft is longer, so a little cut and weld and they will fit.
I just finished up fitting a '46 to my '37. I had a extra '37 shaft I cut off and welded to the '46 shaft. I now have a stock '37 column with a '46 box.
Joe
Good for you, Joe. You will like that set up.
Joe smile
I also put one in my 37 and noticed a big improvement,I am using the 41-6 steering wheel and horn button since I dont trust my welding on important parts. Jeff
