2 members (baldeagle, MickeyP),
101
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49486 08/25/2005 9:01 PM | Joined: Jun 2005 Posts: 68 Member | | Member Joined: Jun 2005 Posts: 68 | i'm gettin' a 58-59 3200 3/4 Apache for spare parts & i want to know what that 2nd little shifter/lever is for next to the gear shifter??? | | |
#49487 08/25/2005 9:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#49488 08/25/2005 9:23 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | watch out,, it might be one of those James Bond deals  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#49489 08/25/2005 11:17 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Could it be a band parking brake from a larger truck if not a transfer case shift? If so it will have a small lock release grip like an old hay rake or disc. | | |
#49490 08/25/2005 11:57 PM | Joined: Jun 2005 Posts: 68 Member | | Member Joined: Jun 2005 Posts: 68 | i believe the truck is 2wheel drive & yeah it has i guess like a "lock release grip like an old hay rake or disc". IF it's not a 4x4 then it's a parking brake & why don't my '58 3100 have it? | | |
#49491 08/26/2005 4:08 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | First off a 3200 is a 1/2 ton long bed. A 3/4 ton is a 3600. The 1/2 ton had a foot engaged parking brake that used the rear brake shoes. 3/4 ton trucks with 3 speed trans used the same setup. The parking brake for the 4 speed on 3600 and up is a hand lever that activates a set of brake shoes on a cylinder in the driveshaft. | | |
#49492 08/26/2005 5:46 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually Cletis, the 1/2T TF trucks have a hand pull park brake under the left corner of the dash  but yes on the driveline brake for 3/4T's Bill | | |
