4 members (TexasJim50, Hotrod Lincoln, baldeagle, 1 invisible), 111 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#49486 08/25/2005 9:01 PM
i'm gettin' a 58-59 3200 3/4 Apache for spare parts & i want to know what that 2nd little shifter/lever is for next to the gear shifter???
#49487 08/25/2005 9:17 PM
Riding in the Passing Lane
Is it 4 wheel drive?
1972 Chevy c10 Cheyenne Super
#49488 08/25/2005 9:23 PM
watch out,, it might be one of those James Bond deals grin
Redryder pix
My Hotrod
#49489 08/25/2005 11:17 PM
Could it be a band parking brake from a larger truck if not a transfer case shift? If so it will have a small lock release grip like an old hay rake or disc.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#49490 08/25/2005 11:57 PM
i believe the truck is 2wheel drive & yeah it has i guess like a "lock release grip like an old hay rake or disc". IF it's not a 4x4 then it's a parking brake & why don't my '58 3100 have it?
#49491 08/26/2005 4:08 AM
First off a 3200 is a 1/2 ton long bed. A 3/4 ton is a 3600. The 1/2 ton had a foot engaged parking brake that used the rear brake shoes. 3/4 ton trucks with 3 speed trans used the same setup. The parking brake for the 4 speed on 3600 and up is a hand lever that activates a set of brake shoes on a cylinder in the driveshaft.
#49492 08/26/2005 5:46 AM
actually Cletis, the 1/2T TF trucks have a hand pull park brake under the left corner of the dash grin but yes on the driveline brake for 3/4T's
