2 members (Peggy M, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#494726 01/18/2009 3:06 PM
U
U Offline
hi went to look at a 1952 chassis cab guy said it was a 3 ton ex fire tanker the info on the plate was- model 1783 - serial 1178301233- engine g29345- body 22- trim 394- paint 131 - GM canada. on a nother plate was max weight 16000lbs any ideas if this is the right info for this truck thanks Rob
uncle buck #494763 01/18/2009 5:17 PM
welcome to the garage Rob - the CDN numbering setup is totally different then the US system, so you won't find much on the details, but that number will be right if the plate hasn't been changed .... the first number being 1 should say it's a 1951 [probably first registered in 52], the next 4 are the series and model 17 83, the rest is the unit sequence number ... yes, the model would be a cab&chassis but would be 2.5T for 16000#
uncle buck #494767 01/18/2009 5:22 PM
3B Offline
Hy uncle buck, the serial number on that truck breaks down as follows
1 = 1951
17 = series code 3 ton, largest Chevy truck produced this year
83 = model code 179" wheelbase
01233 = regular production number
engine number G29345 = G.M.C. 248 c.i.d. engine
If this truck was a 1950 it would have been a Maple leaf 3 ton, but the Maple leaf designation stopped in 1950. The truck should have turn down door handles and vent windows, hope that helps.
3B #494794 01/18/2009 6:22 PM
U
U Offline
it has turn down handels vent windows and it says maple leaf on the hood both sides ? it was in bad shape it has a 2 speed axel the master cylinder was remote on the frame the guy wants $2500cdn i will think some more are parts easy to get it had 20" wheels with 5 stud mounts thanks Rob
uncle buck #494809 01/18/2009 6:55 PM
3B Offline
Hy uncle buck, it should have 5 bolt Motor wheels on it, maybe someone found the Maple Leaf plates, or the hood was transplanted off of a 1950 Maple Leaf. Parts are not too hard to find [no harder than most other 58 year old vehicles], as I said it has a G.M.C. engine in it not a Chevy, this is a full precision bearinged engine, unlike it's Chevy cousin of the same year. It is a nice long wheelbase so you should be able to make it into anything you like.
uncle buck #494812 01/18/2009 6:59 PM
2500 for part of a truck in bad shape?? sounds like a 500$ truck at most, they're not as scarce here as in the UK!!
what area are you in? the praries are littered with old farm trucks, should be able to find a decent 1/2T to 5T 50's truck easy
Flxible #494823 01/18/2009 7:40 PM
U
U Offline
hi i live in nova scotia at the moment moved here from england last year it's a lot colder here it was -19 when i looked it over yesterday .Looks like a trip to usa will be the order of the day there is one on ebay but no title so import to canada might be a problem but not in a big rush Rob
