2 members (Gdads51, Jon G),
100
0
Mod | | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I talked to the guys at Tanks Inc. and they suggested that I use this rollover vent valve. It will vent the tank and also seal itself off in case of a rollever. I mounted it in the right rear stake pocket, ran the hose through the frame then to the tank. I'm not sure if moisture will be able to get in so I'll eventually get some covers for the opening.Thanks for all the input!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | looks good. mind providing a link to where I can get one of those. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | looks good robert, nice job. Tim | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Robert, my only concern is the dip in the fuel line to the vent. It will act like a P-trap on your sink. If that gets full of fuel, it may purge out the vent when your filling, kind of like filling a straw up with water and blowing.
make sure that you have a gradual slop upward to the vent and all will be well.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | It only needs to be above the tank. If it were me i'd mount it just off the fitting on the tank and up the frame a tad.
Just my .02 cents. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | make sure that you have a gradual slop upward to the vent and all will be well. Point well taken. I'll run the line on top of the frame. Thanks.
