3 members (78buckshot, Ridgeback, 1 invisible),
109
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | my speedometer and odometer were not working when i purchased my truck. i finally got around to replacing the cable but still no action! upon further inspection the part that the cable threads onto the tranny seems to be theculprit. the gears spin but the rod or whateve it is that goes into the tranny is broken. its the same type that is at the end of the cable . its like a tang with a bump on one side that has a mating slot in the tranny. hard to explain. anyone know what that part is and how to get another one. thankss | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | forgot to mention its a 36 with the original 4 speed compound low | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Sounds like you should start with a new cable? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | take it to your local Chevy dealer parts dept. They should be able to match it up. | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | i did replace the cable. do you think he chevy parts dealer would have that part for that old of truck(or are they universal from 30's to 60's ) | | |
