0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | onea you guys with the books .... the block is a 68-76 4 bolt and the number on the front pad is KO7 16 TKB ... what was the application and any details?
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | My book lists it as a 400 with automatic, beigna 4 bolt, that pretty much limits it to a '71-'73.
Bill Burmeister | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | It's not in my book that goes up to 1969. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hmmm - it does have a TH400 on it ... any idea of torque?
I'm not sure about leaving this in daBus, thinkin of watching for a 427 or 454, if I can find either cheap, or a 502 - thanks
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Spec books are a little shakey on HP and torque specs, but the one listing I found shows 240 HP net and 410 ft/lbs (1971 specs).
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | geez 410 is respectable, not so much below than an average BB, maybe it'll do - until it blows up  Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I came up with TKB= 1976 pick up, 350, 165 HP. 4 barrel. On the drivers side at the back of the block where the head meets there's an 7 digit cast number. Post that and I can check that too.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ahh, yes, that casting# is why I said 68-76 4 bolt - it's 3970010, which the short list I have says is 302, 327, and 350 so I'm back to a switch!  Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | 3970010 block was a 4" bore shared with those three engines. You have a 350.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | thanks .... on with other things while I wait for an affordable BB to float by!
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Intersting, seems that TKB code got recycled. The book I have only goes to '72, and I have a suspicion that the TKB code listed in there may actually be for a 400 BB (402) rather than a SB. That would explain the high torque spec.
