2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#494555 01/18/2009 1:22 AM
onea you guys with the books .... the block is a 68-76 4 bolt and the number on the front pad is KO7 16 TKB ... what was the application and any details?
Flxible #494593 01/18/2009 2:51 AM
My book lists it as a 400 with automatic, beigna 4 bolt, that pretty much limits it to a '71-'73.
Bill Burmeister
LONGBOX55 #494597 01/18/2009 3:01 AM
Leo Offline
Moderator
Moderator
It's not in my book that goes up to 1969.
Leo #494632 01/18/2009 4:23 AM
hmmm - it does have a TH400 on it ... any idea of torque?
I'm not sure about leaving this in daBus, thinkin of watching for a 427 or 454, if I can find either cheap, or a 502 - thanks
Flxible #494633 01/18/2009 4:28 AM
Spec books are a little shakey on HP and torque specs, but the one listing I found shows 240 HP net and 410 ft/lbs (1971 specs).
Bill Burmeister
LONGBOX55 #494638 01/18/2009 4:41 AM
geez 410 is respectable, not so much below than an average BB, maybe it'll do - until it blows up grin
Flxible #494658 01/18/2009 6:11 AM
I came up with TKB= 1976 pick up, 350, 165 HP. 4 barrel. On the drivers side at the back of the block where the head meets there's an 7 digit cast number. Post that and I can check that too.
Brian
1955.2 3100 Truck
55shaker #494664 01/18/2009 6:24 AM
ahh, yes, that casting# is why I said 68-76 4 bolt - it's 3970010, which the short list I have says is 302, 327, and 350
so I'm back to a switch! frown
Flxible #494666 01/18/2009 6:33 AM
3970010 block was a 4" bore shared with those three engines. You have a 350.
Brian
1955.2 3100 Truck
55shaker #494668 01/18/2009 6:38 AM
thanks .... on with other things while I wait for an affordable BB to float by!
Flxible #494994 01/19/2009 3:09 AM
Intersting, seems that TKB code got recycled. The book I have only goes to '72, and I have a suspicion that the TKB code listed in there may actually be for a 400 BB (402) rather than a SB. That would explain the high torque spec.
Bill Burmeister
