3 members (Guitplayer, Danielbolt, Hotrod Lincoln), 79 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
#494581 01/18/2009 2:34 AM
i have a 52 3800, with a 235, finally got it to run but the heat gauge will not work, it looks mechanical how much of a problem to fix? this truck is for hauling wood, so if it is better to juct get one from the auto parts i will but would be nice to keep it stock any body tackle this? does the sender unhook from the back of the gauge? thanks for your time trying
H Online: Content
The "sender" on your original-equipment gauge is actually a small-diameter tube filled with a liquid similar to Freon that expands when heated. No, it doesn't come apart. It's a professional restorer's job to rebuild that type of gsuge. I'd suggest an aftermarket gauge, either direct-reading or electric, unless you're doing a restoration of the truck. Getting an original gauge rehabbed is pretty pricey.
