| | | Forums66 Topics128,141 Posts1,056,780 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | i have a 52 3800, with a 235, finally got it to run but the heat gauge will not work, it looks mechanical how much of a problem to fix? this truck is for hauling wood, so if it is better to juct get one from the auto parts i will but would be nice to keep it stock any body tackle this? does the sender unhook from the back of the gauge? thanks for your time trying | | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | The "sender" on your original-equipment gauge is actually a small-diameter tube filled with a liquid similar to Freon that expands when heated. No, it doesn't come apart. It's a professional restorer's job to rebuild that type of gsuge. I'd suggest an aftermarket gauge, either direct-reading or electric, unless you're doing a restoration of the truck. Getting an original gauge rehabbed is pretty pricey. Jerry
