6 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, Peggy M, dt235sd), 76 guests, and 5 robots.
Topics128,095
Posts1,056,078
Members48,433
#494303 01/17/2009 5:40 AM
I have a stock '71 C20, 2wd, 350/TH350 AT. It has trailing arm rear suspension with coil springs. Has anyone ever attempted a drive line conversion? Originally, I was going to transfer the cab & front clip onto a different frame with an existing & fully operational drive line, but the bed won't fit correctly. *(1986 GMC frame)
So, I was thinking about retro fitting. But, I think it's beyond my skill level (ie axle alignment, etc). Thanks in advance for your inputs, comments & advice. I've been researching this for a long time.
1971 Chevy C-20 Fleetside Longbed1986 GMC K10 Rock Crawler, 2007 Silverado Z71.
I would look for a rolling 71 or 72 4x4 chassis to use or to see how much frame modification you will need to do to the 1986 frame. Not for sure but I think most 4x4 cabs had a high hump floor. good luck.
hayhauler71 #494339 01/17/2009 12:20 PM
Thank you, I appreciate the response.
