3 members (JW51, tesa, Ponchogl), 49 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
I just got an old 51 GMC. What is a safe cruising RPM for the ole GMC six? My AMC 258 and the Ford 300 could safely run 3000 rpms all day long. Someone told me that those old GMC motors don't like seeing anything higher than 3000 rpm.
3000 is a good benchmark. A fresh motor in good repair wouldn't have problems spinning 3600, but a truck that has been sitting will likely have sticky valves at higher rpms. The 228 6 ctlinder is a good motor. The 270 and 302 6 cylinders are even better.
I've seen a lot of old Chevy sixes run at 4K +. I've said it before and I continue to say it. - most of you guys are afraid of this engine. They didn't exist for so many years without taking the abuse of a whole lot of us threw at them. I know of Jimmys set up for racing that run over 6K.
Go ahead..stick your foot in them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I think I'll stick with 3000 rpm for a cruisin' RPM. From what little I have been able to gather, it sounds like the GMC six is a better motor than it's Chevy counterpart. The thing that worries me is the whole gettin' parts. It doesn't seem like there is a lot out there for those old Jimmy in-lines.
The parts are out there. They aren't in stock in a lot of places that have 235 parts in stock but they can be ordered.
For more specific info on your truck and engine, check out oldgmctrucks.com
