6 members (frogfarmer, Gray_Ghost, dunfire, Otto Skorzeny, jay d, 50Chevy3100), 81 guests, and 3 robots.
Topics128,056
Posts1,055,804
#493348 01/15/2009 1:54 AM
Does my 1944 1 1/2 ton 235 engine work with a pressure cap? What pressure? Also, what temperature thermostat is used?
JLREA #493375 01/15/2009 2:40 AM
Usually a very low pressure cap. And 180 degree is a normal thermostat, but you may consider a 160 if you haul a lot or drive when it's really hot out.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #493996 01/16/2009 4:16 PM
My ranch is at 6700 feet, and most of my driving is at altitudes above 5000 feet, which means water boils at about 200 degrees F. I purchased a 160 degree thermostat and a 4 psi radiator cap yesterday. Do you think this might be about right for my situation?
JLREA #493999 01/16/2009 4:29 PM
very unlikely you'll ever get that thing to overheat if everything is in good condition - if the rad is the same as I had on a 46, it should have a NO pressure cap - careful you don't pop some seams
