| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 19 New Guy | | New Guy Joined: Apr 2008 Posts: 19 | Does my 1944 1 1/2 ton 235 engine work with a pressure cap? What pressure? Also, what temperature thermostat is used? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Usually a very low pressure cap. And 180 degree is a normal thermostat, but you may consider a 160 if you haul a lot or drive when it's really hot out.
Grigg | | | | | Joined: Apr 2008 Posts: 19 New Guy | | New Guy Joined: Apr 2008 Posts: 19 | My ranch is at 6700 feet, and most of my driving is at altitudes above 5000 feet, which means water boils at about 200 degrees F. I purchased a 160 degree thermostat and a 4 psi radiator cap yesterday. Do you think this might be about right for my situation? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | very unlikely you'll ever get that thing to overheat if everything is in good condition - if the rad is the same as I had on a 46, it should have a NO pressure cap - careful you don't pop some seams
Bill | | |
