1 members (Charles in CA),
38
9
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49396 08/22/2005 9:25 PM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Hi everyone, was wondering if anyone has any good feedback on some ideas I have. My truck is a 65 4wd Bowtie (Chevy) -- I currently have 2 parts trucks in my inventory... both are 79's one is 2wd (hi po 350) but complete rust all over body --- other is 4wd currently using it to haul wood for the winter...
My thinking is that I can swap several parts of these trucks over the 65 such as moving gas tank to between the frame- obviously the 350 hi performance engine and maybe some axle swaps possible- considering using the a/c unit if time allows... does anyone know how much other stuff off the 79's that i can swap? Right now I am not concerned about keeping the 65 stock so any help is appreciated. thanks
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#49397 08/22/2005 10:28 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Welcome! I used a 1980 C10 to build my 64, used engine, trans, steering box & brake booster very easily. Brian | | |
#49398 08/23/2005 1:51 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the front suspension and steering will mostly bolt in. | | |
#49399 08/24/2005 12:01 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Thanks for the info guys that should help out a bunch. Is it pretty easy to convert the steering and suspension? Or probably need to expect a few small mods? Have you seen any swaps where the gas tank was moved to the frame and if so is that fairly easy to do? My guess is it would be easy to do as long as brackets and fuel lines are set properly.
