6 members (Hotrod Lincoln, wilbur53, Wayne67vert, HandyAndy, TUTS 59, 1 invisible), 76 guests, and 2 robots.
Topics128,205
Posts1,057,430
Members48,471
What intake, carbs ,header, cam, head work , piston and what ever else that i need to have done .Thanks for every ones help
ODSS President
ODSS President
Do some reading. Search "261". Loads of stuff. People may not be wanting to repeat what they've already said... lot's of information for your build. Also inliners.org this is the place for people that have addressed your quest several different ways.
~ Cosmo
1949 Chevy Half Ton
Also get yourself a catalog from Patrick's, it's loaded with great info. And as Cosmo say's check out Inliners.org, 'Members' have access to tech advisors that can lead you in the best direction for your engine.
1946 1/2-Ton Chevy
Try searching on 261 in The Engine & Driveline Shop forum.
Here is one thread from a few days ago.
Use the Search function
Have you discovered this link currently active in the engine and driveline shop ? Read tclederman's reply and links. Also, checkout the Inliners' site? The '54 261 is a great engine - the high water mark of the stovebolt engines.
Hoyt
the link that hoyt has posted above was started by me. it has been great. check out the articles that tc and sweet linked to.
call patrick's. talked to them the other day. lots of good info, especially do's and dont's, and even some costly unnecessary work i was thinking of.
http://www.patricksantiquecars.com/index.htm
A couple suggestions......find a competent automotive machinist who has a history with Inline GM engines and be ready pay a little extra to get name brand replacement parts. I'd avoid the "rebuild kits" that feature the majority of "Offshore" parts and build on the mindset that the 4 main bearing 261 was initially a "torque builder" engine. Trying to nurse more revs out of a torque engine is just going to cost you big bucks and leave you disappointed with the end result.
By capitalizing on the low-end torque you can set up your GEARING to maximize the potential of your engine. I see no reason to spin a low rpm/high torque engine out of it's torque band. You'll extend your engine's service life, have better fuel economy and overall improved performance. I'm currently running a .72 S10 T5 transmission but have found the Camaro W/C T5 has an even better gear spread which will maximize performance within the torque band. If you haven't driven a GM Inline 6 with a 5 speed (and the correct gearing) you've missed a really fun experience.
As was pointed out, there are numerous "standard" add-on parts to slightly improve performance....some inexpensive machine shop modifications such as drilling the crank for a SBC harmonic balancer bolt to draw on your H/B, tweaking your full-flow filtering system, modifying the timing cover so it can be pulled without dropping the pan, and I also suggest a full rotational balance. So why balance a low-rpm engine? On my 60-235 we found a 13 gram differential in rod weights in the running core I purchased. Regardless of what anybody says, I'm thoroughly convinced it was additional money well spent.
The whole key to getting a good running engine is to find a really competent, enthusiastic engine machinist/builder. There are some little improvements he can suggest that will insure you get the most bang for your buck.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
