| | | Forums66 Topics128,281 Posts1,058,473 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49345 08/22/2005 12:52 AM | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | I have an engine # AD154047....can someone tell me what all this means, year made,where? Thanks | | |
#49346 08/22/2005 1:05 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Looks like a 1957 - 235ci engine. Don't know where made. Here's a link to a decoder . | | |
#49347 08/22/2005 1:44 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I'll repeat my answer from your other post. Since the AD is a prefix, rather than a suffix, it is an earlier engine--a '41 216 (originally built at the Flint plant) used in the 1/2-ton trucks.
You could verify this by checking the block casting number on the Inliners site.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#49348 08/22/2005 1:57 AM | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | Thanks, now if anyone knows who the rebuilder could be I could call them with their stock # and maybe find out if it was converted to inserts or still a babbitt engine! (and when rebuilt) I don't want to make a boat anchor out of a good engine....!!! | | |
#49349 08/22/2005 2:01 AM | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | shipwright, I checked the decode but it came up unknown. This engine also has a rebuild tag on it that says Automotive Engine (or engineering)with the stock #. This is in a 37 pickup and I only got one glance at it. I didn't get to check the usual things to determine or rule out anything and the guy called me with the engine serial #. I'm just trying to do some home work. | | |
