| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | where did you buy the 1'' LED boards?
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | It is a lot better than the price of led tail lights. They have some neat stuff for cheap. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Neil, do you think you can post a good clean shot straight on of the front and back of that LED board? I'd like to see how they have the circuit laied out for the 12v configuration. Thanks Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Sorry about the photo my camera has a 300 mm lens and no macro. If you can't see what you want I'll shoot it at work with a macro lens. There is no connection between the right side of the diode and the neg. wire hole just above it. I think I marked everything else. Read my caption on the photo for more info. http://rides.webshots.com/photo/2461796360103315458TSpdLa | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Neil, I think I can see how they ran the ckt. I believe all you would have to do to change them to 6v would be change the resistors, simple enough. Denny Graham Sandwich, IL
