0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#4929 01/22/2002 4:48 AM
Hey guys thanks for the replies so far this site ROCKS. Anyways, I have some more man. trans questions, as I really know very little about them. If I go to a muncie or a late model 5 spd., what needs to be changed in terms of actually connecting the trans to the block? Will I need a different flywheel? If I do, are all manual trans sbc flywheels the same or will I have to get a specific year to fit the '95 block? The hydraulic clutch setup sounds reasonable enough so far.
Thanks in advance.
'46 grass clippin' Chevy
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
All GM trannies use the same bolt pattern, no matter if small, big or six block. Wait...on rear drive, Wait.....well trucks anyway. Wait, not some of S-10 little engines either. Anyway, some have diff flywheels tho. Diff size clutches maybe. Most should have same trans mount holes up to about 92 on trucks and the Camaro's with the T-5 five speed I think "leans" one way. SO, If I haven't confused you, I have me, you should be safe with muscle car type trannies and bellhousings. Then there's mechanical and hydraulic clutch activation too. New ones have the throw-out bearing and clutch actuator as one with line running to it, no levers to pedals.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
