2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Hi Guys,
Does anyone know where I can get a set of front motor mount studs and nuts for a 56-V8? I have the upper and lower mount brackets and the washer/rubber cushion sets are available seperately but I can't seem to find just the studs/bolts :confused: unless I buy a complete kit with the brackets for $100+. Can anyone help me?
Gene & Jr
horseballz
'56 Chevy 3200
'69 Ford F250
'68 Mustang Coupe/5.0 Roller/T5/Factory A/C
'03 Miata (Wifes Ride)
Anonymous
Unregistered
Anonymous
Unregistered
Can you not pick up some grade 8 hardware somewhere that will do the job? My set up is probably different but the bolt I used was a 3/8-16 x 3.5 grade 8 with an elastic stop nut (ESNA).
